I need some info about A arms.
Nytro Nork
Saint John NB
I recently bent my lower right side A arm on my 09 121" Nytro. I know a guy that has a set for sale but they are off of a 2010 XTX. Does anyone know if these will work? Are there any differences in the A arms? Thanks in advance. And yes the sub frame is bent as well..lol
To tell you the truth, the money you will spend on a lower a arm (check the upper, you probably bent it too), you could put towards a new and much better front end for your sled. Mountaintech's kit I believe is $800. I know a used upper a arm is around $125, and the lower will be higher, add in ball joints, and......
Thanks for the reply. The upper is fine and not bent at all luckily. I snagged a rock at 5mph and the rest is history. This happened yesterday and finally the conditions are perfect here and im off work for 10 days and was really hoping to get out.
Take a really good look at the upper, look for pealing paint, the upper is pretty weak. Just an fyi if you did not look it over perfect. I am not current on if any changes took place on the 2012 arms, but I know shorties and xtx were the same, and I am pretty sure no changes between 09 and 12, but that I cannot say for 100%.
Btw the story about buying the used arms and then wishing they would have bought a new front end is true, that is my brothers thoughts after buying just one used upper a arm this fall, and now driving my sled with the Mountaintech kit, lol.
