viperaddict
- Sep 6, 2004
- Alton NH
- 2003 viper w/monoshock and simmons skis
2011 apex SE
Anyone know for sure if the monoshock from a monoshock 1 will fit in a 128 mono2? waiting on parts for my blown fox mega and wondering if it is possible to swap the coil over kyb from my mono swapped viper into it. Thanks!
Brotherdan
- Sep 8, 2017
- Belmont,maine
Yes all the mono shocks shocks will interchange,mono 1,mono 2Anyone know for sure if the monoshock from a monoshock 1 will fit in a 128 mono2? waiting on parts for my blown fox mega and wondering if it is possible to swap the coil over kyb from my mono swapped viper into it. Thanks!
viperaddict
- Sep 6, 2004
- Alton NH
2011 apex SE
Thanks!Yes all the mono shocks shocks will interchange,mono 1,mono 2
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
I have an Ohlins Mono 1 in place of the mega float in our 14 Apex 128 mono 2.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
Did you convert the compression clicker to manual adjust or just running the shock as is and using the rebound adjuster only?I have an Ohlins Mono 1 in place of the mega float in our 14 Apex 128 mono 2.
I’m running Mono I KYB’s with dual rate spring setups in both of my Mono II’s at the moment.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
Just the shock and rebound adjuster as is.Did you convert the compression clicker to manual adjust or just running the shock as is and using the rebound adjuster only?
