Bustedknuckles
- Dec 13, 2013
I have been trying to increase the air pressure on the rear shock as it is bottoming badly nut I cant seem to get the pressure to increase. I am able to get a pressure reading so I believe the pump is hooked up correctly. Looking for any ideas or answers, thanks in advance.
Try useing an air line from a compressor and not the pump. Your pump could have a failed seal.
ApexSE/Vector
- Dec 12, 2010
Mine does this alot. Remove the pump and re-attach and fiddle with the tightness of the threaded collar once a reading is observed.
Bustedknuckles
- Dec 13, 2013
Thanks for the help, I messed with the connection and all good.
