blade072
- Jan 12, 2008
- Jefferson, Ohio
- 2012 Vector LTX
I just sold my 07 Attak GT and ordered a 2011 Apex XTX.
Can somone tell me the Stock gear ratio and the clutch weights that they are using. I am thinking that they might be using the new 83 gram weights.
thanks for you help.
Jim
Jim
fourload
Check with Ulmer. I think I read somewhere the 11 has 24/37 gears.
morrisond
Confirmed on Yamaha Canada On-line parts fiche
XTX 23/37
128" 24/37
XTX 23/37
128" 24/37
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
They use a new clutch weight "8HG" (they are big like the 8HF weights). Blue-Silver-Blue primary spring, small rollers, pink secondary spring in the 128" models or white secondary spring in the 144" models, and the standard 51/43 helix.
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
Anyone know how much the 8HG flyweights weigh???
sx7001
- Jun 28, 2003
- Sidewinder
RSVECTORFREAK said:Anyone know how much the 8HG flyweights weigh???
83grams empty....
yamashaker
- Nov 12, 2010
- Candle Lake, SK.
- 2007 Attak GT / 2017 Sidewinder LTX
So how much for the total weight with rivets? I have a Yamcharger on 07 Attak GT83grams empty....
sx7001
- Jun 28, 2003
- Sidewinder
The 11+ apex primary weights are 83g empty and just about 95g loaded up. Are you wanting to use these in your 07??
yamashaker
- Nov 12, 2010
- Candle Lake, SK.
Yes have a new set of these weights laying around, I have O/P/O spring, according to the yamcharger folks an additional 4 g needs to be added. The original stock weights filly loaded are 81 g but have a different profile. I was using d&f but the shoulder curve are worn using white spring, not impressed.
