mnydir
- Aug 19, 2010
When I open my side panel my clutch seems to make a rattling noise, and i noticed that the bolt through the rollers is loose on all three. Is that normal?
Also are the weights supposed to be loose to?
basic700
- Mar 5, 2010
- Norwalk WI
- 2018 Sidewinder STX DX 146
2015 SRViper XTX LE
2009 Nytro XTX
All nytros do that
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
I have tried using o-rings to take up the play in the roller bolts but they did not last. I may try some duralon small washers if I can find some small enough.
As for the weight rattle, Super Tip weights are the only ones that eliminate any rattle in clutches as they offer tighter tolerance bushings. Those who are using Super Tip weights I would recommend equally distributing the weight hardware on both sides of the weight to minimize premature uneven wear of the bushings.
