2008 Nytro RTX
my primary clutch is making a rattling noise when it idles and when you get on it she tings. Is that normal? I think I remember hearing it but I don't remember it being that loud.
yox185
2008 Nytro RTX
So you guys think its normal? I am 85% sure it is but i figured it wouldn't hurt to double check
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
Three small o-rings on roller pin bolts eliminates the annoying rattle.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
You have the option of putting some "O" rings behind the pins but that might get you 300 km's noise free. My sleds have all done that. Check them out it takes 10 minutes. If you don't find anything excessivlly loose it's fine.
2008 Nytro RTX
Is it going to hurt the sled, outside of the noise? and should the roller pin bolts be tight or loose?
BADSLED
- May 13, 2004
- Syracuse, NY
What weights are you running? How many miles on it?
2008 Nytro RTX
stock and it has close to 1400 miles
canoehead
- Jan 14, 2011
- NE, Alberta
I torque the pins to the point where they just spin using your fingers. So it's snug but allows the weight to swing without spinning the pin. Don't over torque them!
- 9K
