17Rambler
When I'm going very slow and coasting, then hit the gas, i hear a kerchunk noise. Is that the clutch? Annoying if I am riding slow with my kids as I hear it often.
I am running with the track on the loose side.
TRUE BLUE SINCE 1980
- Apr 11, 2010
- Central PA
- '10 VECTOR LTX
Normal!!!!....... That's the way they are!!!!
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
Probably the transfer rod though you don't mention where you hear it coning from.
17Rambler
front left.Crewchief47 said:Probably the transfer rod though you don't mention where you hear it coning from.
17Rambler
So if it is the transfer rod (and I don't know what the heck that is), is there something I should be doing about it?
rocky18
- Jan 28, 2012
- Rockford, IL
- 1997 Yamaha 600 Venture
2012 Yamaha RS Vector LTX (R.I.P)
2018 Yamaha SR Viper L-TX-DX
- Just below the Cheddar Curtain
Transfer rod
17rambler
I'm going into territory I know little about here...Transfer rod is located in the lower portion of the skid about midway just above the track. Almost horizontal rod with a lock nut and adjusting threaded rod. Info on adjusting it is around page 40 or so in the 2012 manual. It's in the suspension section. Oh one other thing. Mine clunks too. There is another thread on this subject. Some say normal, some say chain adjustment and some say track too loose. I can't get out right now but will readjust each item 1 at a time to check. I will post whenever I get this done. Without snow, that could take a while. I can take a photo if you like. Good Luck
rocky18, aka Mike
17rambler
rocky18, aka Mike
Bluebullet
- Mar 19, 2005
- Massena NY
- Maine
I would check your belt for flat spots, or check the speedo shaft bearing, both have been know to make a clunk noise when taking off. good luck
Crewchief47
- Jan 16, 2006
Yes, Transfer rod is under your butt. You'll have to investigate the other areas mentioned.
theCATman
- Feb 19, 2007
- WI
- Yamaha
It's the clutch. If you put in on a stand you can get it to do it too, but not as noticable since there's no load on the machine.
Don't worry about it and just ride.
17Rambler
Thanks all!!
CaptCaper
- Jan 1, 2007
- Northern N.H.
- 2016 RS Vector XTX 1.25 Lug .2013 RS Vector LTX. Past Machines 3-2007 Attaks 1-2010 Vector LTX.. 2- 2003 VMax 600ER's.
- New Hampshire
I notice our 2010 Vector LTX clunks to get going. Low mileage on it too.
Clunking in a way that can be engageing fast or faster the my other sleds have. I have a 07 Attak and that's smooth engageing.
Is there an adjustment ? make the belt sit tighter in the sheaves at idle?
theCATman
- Feb 19, 2007
- WI
- Yamaha
The way to tighten or loosen deflection is on the secondary with tiny shims that go behind three screws on the back of the secondary.
Get a few & try it, but chances are with just one shim behind each screw then it'll be too tight & the belt will squeal at idle.
So, which do you want. Slightly harsh engagement/clunk, or too tight of deflection with excessive wear at idle & squealing.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Some good info and pics in this post, Blue Dave shows and explains it perfectly.
http://www.ty4stroke.com/viewtopic.php?t=115578
