2012 Apex XTX temp gauge install pic
ShootToThrill
Northeast lower Mi.
Not much room on the dash with a windshield bag for a gauge. This works great and looks good. Warm up light goes off at 68 and high temp light comes on at 220 on the factory gauge. Normal running temp is 170 unless there is ice blocking the rear exchanger. Temp sensor is installed in the horizontal hose with the SLP fitting.
Did you mount the gauge in the bag?
Yes I just trimmed out a hole smaller than the gauge and it's basically the same as mounting it in a pod. The bag is semi rigid and holds it there good. Best part is I only had to drill one small hole for the wires and it's hidden behind the bottom edge of windshield.
