Mike E
I have a 2012 with a ice-ripper track and I'm ready to replace the stock carbides. It does dart, sometimes bad enough to make me uncomfortable. My question is would I be better off with 6 inch duallies or 8 inch singles.
Mike
Mike
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
My vote would be for Bergstrom Triple points and shim the ski rubber. I had great luck with there carbides I put 4000 miles on them and they looked great . Sold them to a friend 2 seasons ago and he is still running them !
They are expensive but worth it.
superb
- Apr 10, 2004
- Ottawa, Ontario
- 2015 Viper turbo, 2013 Apex, 2012 Vector LTX, 2010 Vector LTX
Just go and buy some sno-trackers and all your darting problems will be solved.
Vectornut
- Nov 18, 2007
- Eden, Vermont
- RS Vector
Woodies Dualies have worked very well for me. I have been considering the Ice Ripper Track. Are you satisfied with your Ice Ripper Track?
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Mike E said:I have a 2012 with a ice-ripper track and I'm ready to replace the stock carbides. It does dart, sometimes bad enough to make me uncomfortable. My question is would I be better off with 6 inch duallies or 8 inch singles.
Mike
8 " singles likely will Dart like crazy.
6" Studboy Deuce bars or maybe even 4" if the sled is a shorty, will not dart but will push a bit and knock off a little top end speed. Deuce bars are better than Woody's Duelys IMHO.
Semi Aggressive Sno Trackers are the best solution I have found other than they chew the hell out of certain Ski Guides in a trailer. They don't dart, don't knock off speed, they rail on the trail and they self sharpen.
Best money I ever spent on a sled other than boost and it costs way more.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
As I've never tried the Snotrackers and have only run Woody's Doolies for 14,000 miles, I vote for the 4" or 6" Doolies. Length of carbide will depend on how much ski pressure you have the chassis set to and studs if any (forgot if you mentioned studs or not). I typically get at least 4000 miles on a set depending on conditions. I want to try Woody's Slim Jim's but would have to order them....maybe next time.
How much USD are a set of Snowtrackers?
superb
- Apr 10, 2004
- Ottawa, Ontario
I have run them all, and by far snotrackers are the best in all conditions.
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
Just put on a set of aggressive SnowTrackers and don't look back or worry about what the next guy is doing. Just go ride, you won't be disappointed.
What type of rider are you. If just out for a pleasure cruise then doolies are all yoiu would need. If you like to rail the corners then spend the $$ on Snowtrackers.
I've had 4" 6" 8" singles, doolies, Bergstromm triples, shims and Snowtrackers. The aggressive Snowtrackers are by far the best handling carbide that I have found for my style of riding. Zero darting, no push in the corners and they make the front end feel lighter which means no sore shoulders after a 300 mile ride.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
For about 100 bucks more you could add the Yamaha Tuner Skis that stop a lot of the issues.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Nothing is as important as making sure your front end alignment is spot on.
Without proper toe in/out, no matter what you run, you will still have issues if your alignment isn't correct.
crazynewf
Snotrackers all the way!
Sledhead_BR
- Sep 20, 2007
- Northern Manitoba
- 2008 Vector LTX GT
1997 VMAX XTC
2005 AC 120
APEX 06 said:For about 100 bucks more you could add the Yamaha Tuner Skis that stop a lot of the issues.
apex 06 do you have these? wondering the difference in cornering/push vs a dual runner on the stock ski? I have an 08 vector ltx gt with 4" carbide dualies and it was a huge improvement vs stock single but still get a little push but the darting is gone. debating when it is time to replace the dualies if I will go with the new tuner skis...?
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
I have the Ice Ripper with 6" Woody Doolys and I'm happy with that set up. Used to have single carbides and the Doolys made a big difference.
heffer
- Jan 2, 2017
- milton
- yamaha rs vector
has anyone noticed significant drag with the dualies, snowtrackers, Bergstrom Triple points etc which has been tried to correct darting? Aftermarket skis vs stock Yamaha ones? Any real difference noticed?
