RDCrazy
When sitting for a while I attempt to start it by just turning the key on and wait until it goes through all the pre start checks. Then attempt to start it and it fires then dies. It does this about 3 times before starting and stay running. Is this normal or is there a issue with sled. No codes. Any help with this is greatly appreciated.Thanks
Pre start checks?When sitting for a while I attempt to start it by just turning the key on and wait until it goes through all the pre start checks. Then attempt to start it and it fires then dies. It does this about 3 times before starting and stay running. Is this normal or is there a issue with sled. No codes. Any help with this is greatly appreciated.Thanks
RobX-1
- Coldwater, OH
I would assume he is referring to the gauge pod tach cycling, fuel pumps pressurizing and things like that that occur when you turn the key but do not turn it all the way to start it.
RDCrazy
That is correct RobX1.
Ok, I never wait for that stuff myself.That is correct RobX1.
Confused
- Oct 12, 2008
- Mound, MN
- '21 Sidewinder LTX SE
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
When's the last time you put spark plugs in it?
pdiddy
- Oct 12, 2004
- Southern Maine
- '11 Apex; '16 Apex XTX; '18 Indy 600 SP;
It's not normal. The sled should start and run just like you car. How does it run after warm up? Any bogging or hesitation?
My Nytro would often do this, but usually only stall once.
RDCrazy
It has original plugs in it, only has 1800 miles on it? I just purchased it and have not ran it. I was wondering if possibly old gas would do this. It sat all summer and has old gas in it from last winter possibly. Thanks
new set of plugs would not hurt it. sounding like they could be fouled.
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Not knowing the history of how it’s been run I could agree with maybe throwing some plugs at it but I would want to see some fresh fuel in it too
RDCrazy
Ok thanks....
Snowfreak47
I have a 2011 Vector. I bought it used with 1300 miles and it would do the same thing. Thinking it was bad/old gas I siphoned out as much as I could and added premium non ethanol gas for the next few tanks with no improvement. So before attempting any repairs I added a full can of Seafoam to the next 3 tank fulls of fuel. After the first tank there was a noticeable improvement and by the third tank of fuel it would start first time every time including some below zero starts which would never occur prior to the Seafoam. Not sure sure what all got cleaned in the process but whatever it was it starts like a champ now. Seafoam makes a few different products but the one I used came in a 16 oz bottle that you can pour into your gas tank. It worked for me, maybe it would do the trick for you too?
theCATman
If it's really cold, like 0°F or lower, I've had all 3 of my FI sleds (09 Apex, 10 Vector, 15 Vector) start and shut off, and each time OP LOW has flashed on the screen.
That said, one reason this happens is the oil is thick and doesn't flow quickly enough and the ECM thinks uh oh, no oil, shut down.
This has happened once on the 15 after sitting all summer too.
Unless it does it every single time, I wouldn't be too concerned, and watch for any codes/message on the screen at startup for a reason why.
