egoy936
Hi,
I have a 2012 vector rs with 3,000 miles and the speedo does not work. I have replaced the speed sensor with an OEM yahama speed sensor still speedo does not work. I have tested continuity between the engine computer and speed sensor harness, this checks out. Anyone ideas what to check next? I am thinking either cluster or ECU is bad.
My sled is throwing the following codes 42, 81, 84
Any help would be appreciated
are all the wires seated fully in the plugs? seen others have that issue.
Very unlikely the ecu or dash is bad.
I would check the connectors throughout the harness with the color of wires related to your sensors.
egoy936
Everything looks good but I will double check! Thanksare all the wires seated fully in the plugs? seen others have that issue.
egoy936
Yes I did! I did a continuity where I put one probe on the ECU side and another on the speed sensor side, all 3 wires had continuity
Dara
If the bearing is good. Sorry just had to say it. Maybe you got a second bad sensor.
The codes all indicate bad sensor. Click the throttle a bit to break the TORS loose then I would do another sensor.
The Black/Blue doesn't go to the ecu. It is usually the culprit. Up above the secondary clutch along the frame there is a connector that brings multiple Black/Blues together. Find it and open it up to inspect.
