youngsterx1
Hey guys, I have a 2012 Venture GT that flashes the oil code along with the yellow warning light at the bottom of the instrumentation cluster coming on about 1 min after a cold start? I shut the machine off and it seems to go away. It runs fine but does have a small hesitation at times at first quarter throttle. I have gone for a few rides with it after it doing this and seems to be working well.
Two days later in -20C it did this again? I just changed the oil a week ago to full Yamalube Synthetic with a filter change. Have an 06 Attack and have done plenty of oil changes so not new at this. I am thinking that the oil ascending sensor is giving me problems???
Any feedback would be appreciated.
Youngster66
Youngster66
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
I guess it's the "OP Lo" message you're getting? It's apparently normal during cold initial startup. It should go away shortly. It could also be a reminder to you to not go ripping until the oil pressure stabilizes. Here's a thread on it.
http://www.ty4stroke.com/threads/low-op-on-lcd-display-after-start-and-then-warning-light.122502/
and another in thee RS section:
http://www.ty4stroke.com/threads/is-this-normal.125573/#post-1120830
But then you say it takes a minute before it turns off. So far, all indications say that it should turn off after a few seconds at most. Before the oil change, was it doing the same thing? And if restarting it clears it, I'd be looking at what is causing it. Maybe a flaky oil pressure switch. I'd be checking actual oil pressure using a gauge just to be sure.
BTW, this is actually the Venture Lite / Multi Purpose section but that's OK. You might want to check out the RS General Talk section as that's where the "bigger" Ventures hang out. http://www.ty4stroke.com/forums/rs-general-talk.14/
youngsterx1
youngsterx1
HI,
No its not the op lo light. It is the oil can symbol and the yellow warning light at the bottom of the instrumentation cluster. Sometimes to get rid of it I have to shut the machine down and re start it to get rid of it???
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Re-read my post. The same recommendations are still valid. You should post in the RS section as this might be a known issue with them.
