Sledboy
So I'm up in UP Yooper Michigan and my battery is dead. What's your advise? I keep my sled in heater 55 degree F under garage and it started fine all winter on trips thru yard and pond. I loaded it on my trailer headed to UP and battery is dead at 5 degrees F. I do have HID light by Sled Start and when I parked it in trailer shut off lights were off. So is this may battery or some weird drain on it or just a battery that died. I never put a batt tender on it. So bad battery or weird drain somewhere? Seek advice b4 I sled in UP on Monday.
You sure its the battery and not the relay near the battery having issues?
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Most people find the first time their batteries are subject to cold if they're good or not. My guess is battery. Try a boost and if it fires off you go for a new one.
Sledboy
Thanks Mr. Sled & Canoehead, It was the battery. It lived a spoiled life in my heated garage and did not like the great cold outdoors.
