p-macd10
- Jan 28, 2014
i just bought a 2013 nytro xtx 1.25 (wrote off my 2009 xtx) and was going to stud my track and found there r no tunnel protectors but there is on the heatextanger and yamaha wants a lot of money for them. just wondering if i really need to install the back 2? thanks
Koke1
- Mar 20, 2013
- North Central WI
- 2013 Nytro XTX
Im in the same boat...previous owners told me it will have protectors. Turns out in 2013 they were just an option and not on every sled
Yeah that blows.
p-macd10
- Jan 28, 2014
Studded my track anyways without installing tunnel protectors and no rubbing
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
You could rivet some used Hyfax up in there.
toyota4runner
- Jan 23, 2012
- Manitoba
- '09 FX Nytro
What's your location? I have a set that were drilled out properly when removed and they're still good
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
p-macd10 said:Studded my track anyways without installing tunnel protectors and no rubbing
Its the ballooning at hish speed is were the issue will come up or if one pulls out.
I will have a good set free over summer
toyota4runner
- Jan 23, 2012
- Manitoba
- '09 FX Nytro
My header and heat exchanger still had some scars from studs and ballooning track even with the protectors installed. That's with stock ripsaw with 144 studs and never lost a stud
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
I have a set out of my xtx, brand new, we took them out at the dealer before the sled ever came home, because I installed a 1.75 Backcountry. Let me know if you are interested. Dan
fourload
Just picked up a 13xtx and will stud it before next year and was a little depressed it had no protectors under the tunnel . Love the sled as it rides and steers better than any other NYTRO I have ridden to date. I even liked it better than the Viper they had on a demo ride.
Are these protectors in the tunnel even needed with all the clearance under there? Way more clearance than an Apex.
p-macd10
- Jan 28, 2014
Iv got over 400 miles on with it studded and no problem
fourload
I've talked to my dealer and he said they aren't needed on the xtx? Sounds weird but p-macd10 confirms this on the 1.25 xtx anyway!!
petetown
- Jan 6, 2012
- Melville,SK
- 2011 nytro xtx boooooosted!!!
I don't see how the strips of aluminum would protect against a pull out!?APEX 06 said:p-macd10 said:Studded my track anyways without installing tunnel protectors and no rubbing
- 7K
