#1Wolverine
Thanks so just over 10,000 with taxes and warranty
Sledboy
Ok, I Snow-Checked a 1.75" BackCountry Nytro XTX today! I figured I would try the 1.75" track and if I can't take it on the trails I could sell it and get a 1.35" Cobra track. Now planning all the upgrades to make it a great sled. Roest metal Skid Plate, USB & RCA Power Supply, center shock re-valve and install a custom dual rate spring, Hygear triple rate front springs, OFT bar Relocator. Anything else I need to make it a GREAT Sled?
Sledboy
Anyone recommend any other mods? Phase 2 will be engine performance and tunnel rack.
00-NUKE
Sledboy said:Anyone recommend any other mods? Phase 2 will be engine performance and tunnel rack.
I would recommend a block off plate in the tunnel. It's a cheap, but helpful add on. I used a $12 sheet of 12"x24" aluminum from Menards and cut out the slot for the exhaust. OFT also has a version that they sell for $100 that's pre fabricated. This keeps the snow from building ice in the tunnel which is mostly to keep the weight off.
http://oftracing.com/OnlineStore/index. ... x&cPath=37
FYI: If you decide to go the aftermarket exhaust route, just keep in mind that a fuel controller and clutching or gearing will be required as well. That equals BIG $$$. I'm sure you'll love the Nytro!
Pete
Sledboy
Thanks Pete!00-NUKE said:Sledboy said:Anyone recommend any other mods? Phase 2 will be engine performance and tunnel rack.
Pete
Mine will have the in tunnel heat exchanger, so I'm not sure if that will alleviate the tunnel ice build-up. I may wait and see on this unless the nitro MTX with tunnel heat exchangers are having icing issues too. Does anyone know. If I still need the tunnel plate in would rather install it b4 first snow.
Sledboy
Pete
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
You will be happy with the 1.75, just put some ice scratchers on for marginal trail conditions.
00-NUKE
Sledboy said:Thanks Pete!00-NUKE said:Sledboy said:Anyone recommend any other mods? Phase 2 will be engine performance and tunnel rack.
Pete
That's a good point. I don't know either. Good luck with your new rig! Hopefully the snow is accomodating this year!
