tator
header is cracked. getting a new one tomorrow.
Joshua
- Apr 14, 2010
- Newfoundland
- 2018 Yamaha Sidewinder BTX LE 50TH
Any pictures
petey_sx700
- Nov 17, 2013
- Central, WI
- 2017 Sidewinder LTX DX
2017 Viper STX DX 146
2013 Vector
2018 SRX 120
- West Central Wisconsin
Thinking I may want to pull mine apart and look. had 2700 miles on stock last year. Installed Hurricane kit this year. Rode 230 miles this weekend. Thought I had some exhaust smell and had 4 on boost and 10.0 on afr at WOT. How bad is it to get tank off and take a look?
tator
yours sounds the same petey. it was cracked just like yamadogs. on the seam where all 3 are together. the welds looked terrible. must have had the thief river shop class do them. if the sled is thawed out it takes about a half hour to get to it. all plastics come off. and the two support tubes from the steering column to the tunnel. then just unplugging wires and fuel lines. then the tank lifts out to reveal the heat shield. remove that then you can see all the welds. (clutch side probably) seems to be the trend.
Joshua
- Apr 14, 2010
- Newfoundland
Did you replace your header yet? If so did it solve your problem?
tator
back together tonight. letting the copper gasket sealer to set up on the header/turbo flange connection. will test tomorrow or sunday.
Jman345
- Jan 14, 2016
- Lindsay
- 2014 Yamaha viper xtx
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Mine broke last year. Welded it and put back. Factory welds look horrible. My weld are still good.
Matt83
- Mar 27, 2015
- London
- 2015 Viper LTX
Has anyone been having cracked header problems with the 2015's? Tator told me about this already and i checked my header and found nothing. Yamaha started adding the gusset on the 15's so the area behind isn't visible
If anyone is out if warranty and needs one I have 2 1 out if the 14 that was replaced last year and 1 with40 miles on it out of my 15
Hurricane190
- Feb 6, 2018
- Oshawa
- 2014 sr viper Ltd 137 huracane turbo 190hp
I'm having the same issue when I installed my Turbo first I ended up running perfect loved it but shortly after I started running low boost and Trace the problem back to a broken bellows in the blow off valve replace that and everything went back to normal. She still never ran more than about 5 lb of boost ever with the sled. I noticed my Boost decreasing from 5 to 4 and now I'm down between 3 and 4 lb of boost. I took a part the exhaust where it comes out of the header into the turbo where the copper gasket goes and I found a exist leak. I was hoping this was my problem just don' want to put it all back together if the header is cracked. Do you think this leak looks like enough to drop 1-2lb of boost? Thanks for your help mike. Sry I can not seem to get the pic to upload.
frozenboogers
- Nov 22, 2015
- wisconsin
- 2014 sr viper rtxse
When my header cracked i could hear it in the tunnel....( Set the park brake before sticking your head in there)
johan
- Jan 19, 2015
- sweden
- Sweden
- Viper Xtx mcx 270
1. 2016xtx le cracked header
1. 2015 Ltx se cracked header
We welded it and I had not had any problems after that. Really bad oem welds on it. It was leaking on 4 different places on 2016 and 3 different places on 2015.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Has this been a problem with non turbo'd Vipers? I was riding in some deep snow yesterday and on the throttle hard when the engine got loud but it's a low somewhat muffled rumble. I thought maybe it was a blown muffler but I don't see a problem with it and the tone really doesn't fit a bad muffler leak or what you'd get out of some of those louder aftermarket mufflers. At low speeds it's not overly noticeable but under hard acceleration it's annoyingly loud.
I got it inside this morning and set the garage thermostat to defrost so hopefully I can find out what's going on later today.
