DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
Have you ran your Sidewinder along side of the Vector and checked the speedo?
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I have not but I know that the Vector reads higher. The 2012+ Vector should read around 6% high. I have never checked my Sidewinder against a GPS but I believe they are very close. 100mph on the speedo on the Sidewinder is likely around 98mph on GPS.Have you ran your Sidewinder along side of the Vector and checked the speedo?
DGZRT
- Feb 23, 2006
I was thinking that it might be faster than you think . If you compare it to something you know is close . My Vector shorty has 6k on it and only a soft start spring and it keeps up to my brothers 1200 skidoo. I have not run it against my 1200 but my Vector feels totally different when accelerating. The 1200 feels more explosive but the Vector is sneaky fast .
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
The 136 studded Ripsaw 2 track and the need to run it loose is definitely scrubbing off some of her speed. The sled used to top out at 96mph on the speedo when it had a studded stock 121" Ripsaw track.I was thinking that it might be faster than you think . If you compare it to something you know is close . My Vector shorty has 6k on it and only a soft start spring and it keeps up to my brothers 1200 skidoo. I have not run it against my 1200 but my Vector feels totally different when accelerating. The 1200 feels more explosive but the Vector is sneaky fast .
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
Our season here is done, so no more testing. In the offseason, I'm going to replace both clutch springs, inspect rollers and weights, check driveshaft and jackshaft bearing, clean clutches and check alignment.
I checked the secondary slides tonight and they look good.
dmaxx
- Apr 5, 2006
- sw Michigan
- 2014 Apex XTX, 2012 Apex SE, 2000 Vmax 700, 2000 AC Z-370, fast
- White Pigeon, MI
My wife's LTX has no problem running 100+ with studs.The 136 studded Ripsaw 2 track and the need to run it loose is definitely scrubbing off some of her speed. The sled used to top out at 96mph on the speedo when it had a studded stock 121" Ripsaw track.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Right... but yours doesn't need the track to run loose. That's where the big difference is. Plus, the speeds I am talking about are on typical groomed trails, not a harder/firmer terrain.My wife's LTX has no problem running 100+ with studs.
dmaxx
- Apr 5, 2006
- sw Michigan
- White Pigeon, MI
Groomed trail. Track runs a little loose also.Right... but yours doesn't need the track to run loose. That's where the big difference is. Plus, the speeds I am talking about are on typical groomed trails, not a harder/firmer terrain.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Have to run more than 1.5" of free sag on ours.Groomed trail. Track runs a little loose also.
dmaxx
- Apr 5, 2006
- sw Michigan
- White Pigeon, MI
I run nearly the same. Also have Excell wheel kit and a homemade clutch kit that works great.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I just ordered an LTX rear arm, rear drop brackets and the rear uppers wheels with mounts to fully make this a true LTX skid. Hopefully that makes a difference.
