Barney Maclean
- Oct 15, 2014
- ontario
- 2016 Yamaha Viper RTX SE
Gentlemen
I appologise if this topic has been beat to death but I am a new Yamaha Viper owner! The Big switch from Skidoo 800Etec!
Anyway my question is: Are the stock carbides good enough for trail riding(no deep snow) on my RTX? I have 135 studs and MBRP trail can.
Any advice would be Greatly Appreciated!
Barney
Ontario Canada
Barney
Ontario Canada
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
For me the stock ones were junk. These are great no push and no darting on my XTX.
https://www.yamahapartsandaccessories.com/product/details/split-runner?b=Snowmobile&d=3|3&f=2014|32
Barney Maclean
- Oct 15, 2014
- ontario
Thanks Shagman!
Barney
Barney
MCApex44
- Mar 30, 2006
- Western New York, Chautauqua County
- 2014 Viper RTX SE (sold)
I tested the single carbide on the stock skis. I also tested the Curve skis and even the Pilot skis on my 2014. Ultimately, I ended up going with the stock skis w/ 6" Double Downs by SnowStuds which were $129 (Woodys Slim Jims are basically the same thing but they are around $150). Easy/light steering effort with no darting. I ride aggressive and have had no complaints on handling.
24 yamaha
- Oct 3, 2014
- Stevens Point
- Yamaha Viper
Are you running a RTX, LTX, or XTX studs or no studs?
Barney Maclean
- Oct 15, 2014
- ontario
Thanks i will check them out!Are you running a RTX, LTX, or XTX studs or no studs?
Barney
Barney Maclean
- Oct 15, 2014
- ontario
Rtx, 135 studsThanks i will check them out!
Barney
savageman69
- Apr 21, 2014
- 2014 arctic cat zr 7000 limited
not to hyjack but what would be the best carbide setup to run with no studs?...i found the stock ones not to bad but always would like to improve
MCApex44
- Mar 30, 2006
yep...you got itRtx, 135 studs
MCApex44
- Mar 30, 2006
IMO, I'd bet (with no studs) the 4" slim jims would be the way to go. If you were studded I'd say 6"not to hyjack but what would be the best carbide setup to run with no studs?...i found the stock ones not to bad but always would like to improve
Studroes144
- Oct 30, 2013
You're running the cat 7000 correct? If so didn't all cats come with staggered dual carbides? My buddies xf7000 did and I had no complaints about his with no studs. No darting at all and steered just as easy as the stock viper skis
24 yamaha
- Oct 3, 2014
- Stevens Point
- Yamaha Viper
I'm running an xtx with out studs. Any suggestion for trail handling? Is it worth buying aftermarket skis?
My Pilots are slightly better than stock but I would not put them on again. But I rode Viper 129 and a xf7000 137 with Curves and they never pushed and had easier steering than my Pilots. I know I should take the plunge and buy them but they are expensive. Cant really say on darting since I dont remember riding on a hardpack trail all year last year. The biggest issue and something to consider is if you have 2 sleds with wide skis it is a pain in the butt trailering. Phazer has Pilots also (which work awesome on it) but you have to overlap skis and if you use a ramp it might not be wide enough. Curves are wide also same issue. I plan to try narrowing up the stance on mine hoping to help push and this trailer issue with Pilots if that doesnt work I will just bite the bullet and get the Curves.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
I have these as well and I will buy them again when they wear out. No darting and very little pushing.For me the stock ones were junk. These are great no push and no darting on my XTX.
