Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
I just picked up a bottle of yamacool at my local dealer. 60/40 mix of ethylene glycol. Topped off my coolant. I was reading on another thread that Yamaha recommends changing the coolant every two years. I don't know about that. My manual says to check yearly and add coolant if needed, and to bleed system if needed. Nothing about changing it out.
Coolant should be changed because additives in coolant wear out. Two years seems sooner then I would change it! GM OAT is 5 years, I think that is when I changed it in my Warrior! Should change it again now!
