snowman4
I was going to get a Cat RR this year and decided to until 2015. The 2015 RTX LE in whit and blue has my attention.
Has anyone been to or found out if the rear suspension has the same as the RR' rears suspension? Like the beefier rails and the better shocks? Or is it the same as the Sno Pro?
If that whit and blue RTX LE is the same as a RR, I'm ordering and buying a Turbo!! Hahaha
vsmpowered
- Feb 16, 2009
- Rochester , NY
- Nytro xtx Viper ltx se
2013 rr is different then 2014 2015. rtx le is like the 2014 2015 rr
Same
snowman4
Thanks for the response guys, did you see the RTX LE at a show in person and check out the rails?
From all the pics and videos Ive seen it looks like the rails are the same as the SE model or a Cat Sno Pro. If that was the case the only difference between the 2 is the front shocks(Fox Evo's) and the 1.7 inch Sno Cross track. And then the only difference in the Orange and Blue RTX LE would be the front shocks.
I can't wait to talk to my dealer tmrw, hopefully he can't get the correct info from a Yamaha Rep.
I really hope both these RTX LE models are exactly like Cats's RR. I know the 2013 had the actual Sno Cross rails but the 2014 and 2015 RR have beefier supports on the chassis and the rails have a lot less holes in them.
hahahaha i can't stop thinking about snowmobiles! This would be the model Ive always dreamed about, 4 stroke race chassis, 1.7 track and a after market turbo!!
YamahaTim
- Sep 21, 2013
- Farmington, MN
- 2014 Yamaha Viper LTX SE MPI Turbo
snowman4 said:I was going to get a Cat RR this year and decided to until 2015. The 2015 RTX LE in whit and blue has my attention.
The cat RR has resivoir shocks in the skid, I doesn't look like the Viper LE does.
fxnytroxtx
Guest
YamahaTim said:snowman4 said:I was going to get a Cat RR this year and decided to until 2015. The 2015 RTX LE in whit and blue has my attention.
I could be wrong but pretty sure that le has reservor shocks with clickers.
It does.
vsmpowered
- Feb 16, 2009
- Rochester , NY
Le is same as 2014-15 rr
