weasel33 said:I agree, I ordered a blue and white le and don't want the 1.7 inch track. How come if you spring order one you can't ORDER it the way you want!
Yeah give us a handful of options like:
Color
Track
Shock package
and last but not least:
turbo
1tp
- Feb 2, 2014
- Central Wisconsin
- 2015 Viper R-TX LE Clutched and Canned
2014 Viper L-TX SE Clutched
I was told that starting next season manufacturers need to race what they sell. Needs to be exactly the same as what's offered to the "public". The blue/white R-TX fills this requirement. Not sure how many they need to actually make or sell.
billbies
update to snowchecks the XTX LE model is available for the MPI turbo promo
mattyg1405
billbies said:update to snowchecks the XTX LE model is available for the MPI turbo promo
You get the turbo for 2000 and the warranty is good for the xtx ???
YamahaTim
- Sep 21, 2013
- Farmington, MN
- 2014 Yamaha Viper LTX SE MPI Turbo
Only with a 2.25 lug and in certain states.
RXVIPER
- Mar 4, 2010
- Shelburne ,Ont
- 2014 SR Viper LTX
2003 RX-1
Does anyone know if u can use the fox zero piggyback shocks for the rear skid on the ltx SE from the 2014 zr 9000 RR ? I seen them on the RTX le they had at the 2015 sled show.
Yes you can but the rod under the 14 rear shock has to be replaced with two rods to clear the rezzy. I also believe the ltx has a longer rear shock.
RXVIPER
- Mar 4, 2010
- Shelburne ,Ont
- 2014 SR Viper LTX
2003 RX-1
Thanks ,u are saying there's a rod under the 14 ltx SE ,there's two rods beside the shock right?
RXVIPER
- Mar 4, 2010
- Shelburne ,Ont
- 2014 SR Viper LTX
2003 RX-1
need a clearer understanding of what u mean. Thankscannondale27 said:Yes you can but the rod under the 14 rear shock has to be replaced with two rods to clear the rezzy. I also believe the ltx has a longer rear shock.
Sorry. You are correct the ltx has two rods. So a rezzy shock from a rr would clear. The length is different though.
RXVIPER
- Mar 4, 2010
- Shelburne ,Ont
- 2014 SR Viper LTX
2003 RX-1
thanks appreciate the information.cannondale27 said:Sorry. You are correct the ltx has two rods. So a rezzy shock from a rr would clear. The length is different though.
