Wannaviper
- Mar 18, 2014
- West Gardiner, Maine
I can't say that I understand it, but my 2014 had me convinced that it had tight valves at the end of last season. I don't have the invoice in front of me, but I don't remember that they changed the plugs or did any mechanical work other than changing the oil. Honestly, I was amazed at how well the sled ran after it was reflashed.Seems odd that a re-flash would cure this. Seems strange that it will run OK, on a given flash, then gradually decline to mimic tight valve symptoms.
Do the flashes, or programmings, wear out? Do they slowly degrade to the point of drivability issues?
There's something more here. Just don't know what.
SGVIPER
- Dec 15, 2019
- Ontarii
- 2015 Sr viper
I called the dealer to check and it doesn't have the current ecu flash. I will have to find time and get it over while we still have no snow.
Barry
- Mar 11, 2015
- bridgewater
- SR Viper
I think I will do that. My sled had 8000 miles and I checked valves and two exhaust valves where at 0. So they did need it. Lots of work. Still little hard starting but when it starts it keeps running. So maybe Flash will helpI have a 2014 with @ 9,800 miles on it and at the end of last season, it seemed to have the symptoms attributed to the tight valves, including all the symptoms you described. I took it into the dealer and he said the valves were fine. He did the latest reflash, and all those symptoms disappeared! It does turn over a little longer before firing, but it is starting and running great, and it has better acceleration. If you are having those issues and the sled does not have the latest reflash, reflashing will probably solve your problems. If you have your VIN #, the dealer should be able to tell you over the phone whether the sled has been reflashed. If it hasn't been reflashed, set up an appointment to do it while you wait, it only takes a few minutes.
Phazer2Viper
- Apr 14, 2014
- Slinger, WI/ Three Lakes, WI
- 2015 Viper LTX-DX 15,000 miles and counting!
2008 Phazer GT 128" track 10,444 miles (sold)
2008 Nytro RTX 136" 3800 miles (sold)
2000 Phazer 6500 Miles (Sold)
1990 Phazer II 10,000 miles (sold)
Brought it into the local dealer and 5 of 6 valves were tight and 2 had 0 clearance. Plugs were a mess too. Luckily it was covered under my recently expired warranty. It was going to be 6.5 hrs of shop time plus parts.
Barry
- Mar 11, 2015
- bridgewater
- SR Viper
I’d pay to see someone do that job in 6.5 hrs. I think it’s over that just to get to valve shims. WOWBrought it into the local dealer and 5 of 6 valves were tight and 2 had 0 clearance. Plugs were a mess too. Luckily it was covered under my recently expired warranty. It was going to be 6.5 hrs of shop time plus parts.
Phazer2Viper
- Apr 14, 2014
Yamaha only pays 4.5hrs for the job. He was thinking it would take more like 8 but was going to cut me a deal. So hopefully it stays within the specs for a long timeI’d pay to see someone do that job in 6.5 hrs. I think it’s over that just to get to valve shims. WOW
pdiddy
- Oct 12, 2004
- Southern Maine
- '18 Vector 129", '18 Indy 600 SP
What kind of oil are you running badams262?
Phazer2Viper
- Apr 14, 2014
The full synthetic yamaha oilWhat kind of oil are you running badams262?
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
May not be applicable, but like our older hp laptop...stuff happens. A system restore brings it all back fast and good. We have a dodge that stalls with a little throttle sometimes. Not often, but once I disconnected the battery forcing a reboot, and it runs and starts like new. Have done this on an 05 neon too. Probably never know why, but it happens.
Norse
- Jan 1, 2019
- Sápmi
- Norway
- 2013 Arctic Cat M1100 HCR 162"
Boondocker turbo 250HP(sold)
2016 Yamaha SR Viper MTX LE 162"
MCXpress 270HP, lots of mods (sold)
2021 Arctic Cat M8000 Hardcore Alpha 155"
N/A (sold)
2023 Yamaha SW MTX LE 153"
M&M Racing 270HP, Elevate, lots of mods
Does the ecu "learn" and make adjustments over time?
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Without a working o2 sensor there's no way that it can. I don't think these ECU's are that sophisticated anyway. Certainly nothing like what we are used to in our cars.
SGVIPER
- Dec 15, 2019
- Ontarii
- 2015 Sr viper
I took it in to get the updated ecu flash. I started it to unload and it took forever to fire up. Got it in the garage and reved it up to find out it has a hanging idle now. This is sad how they can't seem to perfect these things after this many years of issues
SGVIPER
- Dec 15, 2019
- Ontarii
- 2015 Sr viper
Also forgot to add that the stall issue went away so I guess that's one positive lol. Hopefully the cold starts aren't always that bad.
snowfever27
- Jan 7, 2015
- Vermont
- 2015 Arctic Cat XF7000
2009 Yamaha Nytro XTX (sold)
2007 Yamaha Phazer FX (sold)
2005 Ski-Doo MZX 800 Adrenaline (sold)
2003 Arctic Cat F7 EFI (sold)
2007 Yamaha Attack
2009 Polaris 600 Dragon SP
- Vermont
I just did the new flash on my XF7000. It cranks longer but starts the first attempt. Before it would take 2-3 attempts to start. It isles smoother now but I did notice it does have a very brief (2-3 seconds) having idle that quickly settles to a much smoother ideal. The altimeter is more accurate now too. I’m glad I flashed it, I’d rather have it start the first try, even if it cranks longer. My sled has 1,900 miles, brand new CR9EK plugs and brand new battery.
SGVIPER
- Dec 15, 2019
- Ontarii
- 2015 Sr viper
Good to hear. I have been starting mine all night and have to say the warm starts are alot better. Hopefully that first cold start was a fluke and glad to hear that the hanging idle may be normalI just did the new flash on my XF7000. It cranks longer but starts the first attempt. Before it would take 2-3 attempts to start. It isles smoother now but I did notice it does have a very brief (2-3 seconds) having idle that quickly settles to a much smoother ideal. The altimeter is more accurate now too. I’m glad I flashed it, I’d rather have it start the first try, even if it cranks longer. My sled has 1,900 miles, brand new CR9EK plugs and brand new battery.
