Rich Kay
- Mar 29, 2006
- SE MI. Howell
- Yamaha apex rtx
Need complete number that is on center skid shock. Mine is wore off from track debris. Make sure your sled is as listed above...not a SE model.
Thank!
Thank!
Rich Kay
- Mar 29, 2006
- SE MI. Howell
- Yamaha apex rtx
Nobody must know what this means...……….Need complete number that is on center skid shock. Mine is wore off from track debris. Make sure your sled is as listed above...not a SE model.
Thank!
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
Mines wore off to but part # should be listed on part site! I emailed hygear last year for a rebuild kit and they have it so they probably could help.
Rich Kay
- Mar 29, 2006
- SE MI. Howell
- Yamaha apex rtx
Thanks, I will give them a call. Yes I am looking for a service kit for that reason also. Have you serviced a set off of a LE ( fox qs3's)?Mines wore off to but part # should be listed on part site! I emailed hygear last year for a rebuild kit and they have it so they probably could help.
hellflyer
- Dec 2, 2008
Yes! I've revalved them first then went with the dsc valves to replace the 3 position clicker. Much better with adjustable hi and low speed.set it and leave it. Takes a bit to get them where you like them but worth it.
Rich Kay
- Mar 29, 2006
- SE MI. Howell
- Yamaha apex rtx
Is this set up available at Hygear?Yes! I've revalved them first then went with the dsc valves to replace the 3 position clicker. Much better with adjustable hi and low speed.set it and leave it. Takes a bit to get them where you like them but worth it.
hellflyer
- Dec 2, 2008
Yes! It's on there Web site if you look up your year and model it gives you there up grades.Is this set up available at Hygear?
