2016 MTX tie rod hitting A arm?
did you get the shocks shortened? i tried the 38'' shocks and all was good until i made a full turn with the skis off the ground
Yup I am using the shortened shocks. Never tried the longer ones from my 38" kit. But yes full turn with skis off the ground they hit. Even at rest the left side is close. The right side is not really an issue. I think there is a casting mistake on the left spindle and mounted lower than right. Not 100% though.
could it be that something on that side of the sled is bent or tweaked? my 2015 with 36'' kit is not even close to touching without the skis off the ground.
you need to shorten your shocks again
I tried to put my kit on with 38" kit shocks and the left side hits the bottom a-arm
I have the shortened shocks though already so I did not need to shorten my shocks I had on the 38" kit. My longer shocks are removed and the proper ones are installed. The shocks I have running are off a 2016 viper mtx le. So everything should be the same.
Can check on my 2016 Mtx during this weekend.
Yes it is Yukon. I just went out to the trailer to check. Full turn left on left side while I hold sled in the air it touches ever so slightly. Once I let go of the sled and let it sit on the ground there I no touching.
