rosco
Sorry if this info is already on here. Search did not turn up an answer.
2017 viper RTX with base shock package. Is the centre track shock spring dual rate and if so what rates?
Would the AC 2704-229 dual rate 160 260 be an upgrade to this model year?
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
NoIs the centre track shock spring dual rate and if so what rates?
Yes, has worked out for some but not for others. What are you trying to accomplish with this spring?Would the AC 2704-229 dual rate 160 260 be an upgrade to this model year?
rosco
I have read, a smoother more comfortable ride in light chop, less steering effort and overall better handleing.
DennyTuna
- Jan 28, 2017
- Ohio
97 SX Vmax 600
I don't have experience with that spring, hopefully those that do will chime in. I do however have dual rate springs in my Viper and Sidewinder.
rosco
What rate is your viper centre track spring?
DennyTuna
- Jan 28, 2017
- Ohio
97 SX Vmax 600
Can't remember off hand but more to it than just the center shock spring. Everyone in my group is running John Sherrard's set up. This includes correct torsion springs for rider weight, dual rate front shock springs, trac link adjustable limiter strap and dual rate center shock spring. Johns set up calls for getting the center shock out of the way, lowering the front end and sucking up the limiter strap. With this set up we have extremely aggressive handling with light steering, smooth ride and big bump protection. Been there with a stiffer center shock spring, I really don't think it's a cure all, better than stock for sure.What rate is your viper centre track spring?
