RAMSOMAIR
Ship it USPS and put "gift" if you are not in a rush.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
been shipping to Canada for years. Use USPS and do it online. Just fill in the the description as a steel spring and value it at around $12. I've never had any problems.
McLovin
- Jan 30, 2017
- Manitoba
- 1997 Mountain Max 700 144 1.5
Hope someday to figure out a way to ship to all you Canadians reasonably. McLovin thank you for the kind words. Its all packaged up and should go out tomorrow before I leave for weekend. Just have to figure out the stupid Customs form. Any tips to get this through customs best way. I heard saying its used parts works?
Just had to mention that I was wrong for assuming longer shipping time to Canada from USA. It took 4 business days or 6 week days! No duty charged. Very impressed. Shipping was quite reasonable for that speed. Thanks again man.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
It varies. I've seen it take a few days or up to a couple weeks depending on what customs decides to do that day. Anything under 3lbs 3 oz is under $20 through USPS but anything over that and there's a big jump in shipping cost.
Awesome! Thank YouJust had to mention that I was wrong for assuming longer shipping time to Canada from USA. It took 4 business days or 6 week days! No duty charged. Very impressed. Shipping was quite reasonable for that speed. Thanks again man.
razor_220
- Dec 21, 2012
- Saskatchewan
- Yamaha Nytro X-TX(sold)
Yamaha SRViper X-TX(sold)
Yamaha sidewinder B-TX
Hey guys!? I would like to get a new spring for my shock. Cannondale!! Looks like you the guy!! My ridein weight is around 230lbs. Where do I go and purchase?
Just PM me your Name and address for a shipping quote. 160# spring is $70. I also can get a 180# 160 will be enough on your BTX. I just shipped to Manitoba for $17. Not sure what it will be to you. Thanks!Hey guys!? I would like to get a new spring for my shock. Cannondale!! Looks like you the guy!! My ridein weight is around 230lbs. Where do I go and purchase?
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
If anyone is sick of busting knuckles when adjusting center shock preload with the crappy spanner wrench that comes with your sled, I found a nice upgrade... thicker material so it doesnt slip off the nut, and the angle let's you work in a confined space better than stock.
I'm just getting ready to Plasti-dip the handle to make it even better.... And blue. ;-)
there, that's better.
Source is:
UTV /Offroad 2.0", 2.5",& 3.0" Shock Dual-Rate Hardware Spanner Wrenches | Schmidty Racing
https://www.schmidtyracing.com/Dual-Rate-Hardware-Spanner-Wrenches-p/st-sr-drsw.htm
The wrench you want is the Fox 1.5 preload wrench, about $18.
It was an easy sale since I need it for center spring AND my new Fox H1 - 1.5 Zero Pro Rear Shock from Hygear.
there, that's better.Source is:
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
If anyone is sick of busting knuckles when adjusting center shock preload with the crappy spanner wrench that comes with your sled, I found a nice upgrade... thicker material so it doesnt slip off the nut, and the angle let's you work in a confined space better than stock.View attachment 150305
View attachment 150306 there, that's better.
Source is:
Thanks. Have one coming.
JCviper
- Feb 27, 2016
- Morrice, Michigan
- 2016 SR Viper LTX-DX
- YAHOO
- jcstang06@yahoo.com
- Jcgoblue2
I recently replaced the tuners on my 2016 viper ltx dx with C&A xpt's. They track great and there is virtually no push anymore. The main difference has been that turning requires a lot more effort. Would Bills spring help to alleviate this?
Yes. For sure. But I have to ask if you tried cranking up your stock spring?I recently replaced the tuners on my 2016 viper ltx dx with C&A xpt's. They track great and there is virtually no push anymore. The main difference has been that turning requires a lot more effort. Would Bills spring help to alleviate this?
JCviper
- Feb 27, 2016
- Morrice, Michigan
- YAHOO
- Jcgoblue2
Not yetYes. For sure. But I have to ask if you tried cranking up your stock spring?
JCviper
- Feb 27, 2016
- Morrice, Michigan
- YAHOO
- Jcgoblue2
Not yet
i will try that firstYes. For sure. But I have to ask if you tried cranking up your stock spring?
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
I've found that the center shock preload has a big impact on steering effort and push in the corners. It's a delicate balance that you need achieve by tweaking the center spring preload. Tighten the spring two turns at a time until the steering is light as you want, but too far and you will be pushing in the corners again.
yes once close 1/2 a turn is very noticeableI've found that the center shock preload has a big impact on steering effort and push in the corners. It's a delicate balance that you need achieve by tweaking the center spring preload. Tighten the spring two turns at a time until the steering is light as you want, but too far and you will be pushing in the corners again.
