I am about 185-lbs undressed. Do you guys think the Cat 2704-229 160/260 center shock spring would be too stiff for me on my 17 LTX SE? I ride aggressively and mostly in the New-berry-Grand Marais-Seney-Munising areas in Michigan so there is a LOT of time spent on whooped out trails. I currently have the stock 90/250 spring with minimal preload on it. The sled handles corners great but I am also experiencing the rear bottoming out easy on somewhat hard hits. Hard enough to have track clip marks on the top side of the plastic torsion spring holders. I have the rear torsion springs set on the middle position (these are SRX/Thundercat torsions that have less preload but a higher spring rate than the stock LTX torsions).
Also, when you guys are listing preload measurements (threads showing) on the center shock, is that with the limiter straps set or before the spring/shock is sucked up a little by reattaching the limiter straps?
