kimcoop1324
- Oct 7, 2013
- New Hampshire
- New Hampshire
I have a 2018 ltx dx that I bought at end of season last year. I have been trying to follow all the posts concerning the clutches and belt blowing and changing the stock set up to remedy this issue. So far I had 2 mm removed from my secondary shaft and changed the secondary spring to blk/orange wrapped at 6/2 as dalton Inc suggested. What spring should I use on primary clutch? I was thinking blk/bronze since I'm all stock as of now. Also would these new Springs still require spring pockets to be machined to stop coil bind? Or would that be not necessary since these Springs are shorter? Thanks for any help
krm
- Apr 22, 2016
- ny
First get the Hurricane alignment tool ,then go from there .No need to change drive spring ,but i'd put 14.5mm rollers in .Get the newest dalton driven spring and set it up ,You'''ll be good to go .Till you try a Boosted one LOL
kimcoop1324
- Oct 7, 2013
- New Hampshire
- New Hampshire
I did buy the alignment tool and the offset is spot on according to the tool. I also changed the secondary stock rollers from thunder products. So I should change the primary ones also?First get the Hurricane alignment tool ,then go from there .No need to change drive spring ,but i'd put 14.5mm rollers in .Get the newest dalton driven spring and set it up ,You'''ll be good to go .Till you try a Boosted one LOL
krm
- Apr 22, 2016
- ny
If you like ,But the 14.5mm rollers last/work better .I did buy the alignment tool and the offset is spot on according to the tool. I also changed the secondary stock rollers from thunder products. So I should change the primary ones also?
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Im confused, since 14.5 mm rollers are stock, what are you using?
kimcoop1324
- Oct 7, 2013
- New Hampshire
- New Hampshire
I'm guessing the rollers in the stock primary are larger than 14.5. I may be wrongIm confused, since 14.5 mm rollers are stock, what are you using?
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
They are not, 14.5mm is what comes in a Sidewinder from the factory.
kimcoop1324
- Oct 7, 2013
- New Hampshire
- New Hampshire
OK that's good to know. So would I need to machine the primary pockets to prevent coil bind if I use a new dalton spring? I believe they are shorter than stockThey are not, 14.5mm is what comes in a Sidewinder from the factory.
krm
- Apr 22, 2016
- ny
Your right ,I'm using 15mm rollers .Had to measure them .Im confused, since 14.5 mm rollers are stock, what are you using?
krm
- Apr 22, 2016
- ny
I'm using Dalton spring with no machiningOK that's good to know. So would I need to machine the primary pockets to prevent coil bind if I use a new dalton spring? I believe they are shorter than stock
kimcoop1324
- Oct 7, 2013
- New Hampshire
- New Hampshire
what spring are you using and are you stock or tunedI'm using Dalton spring with no machining
krm
- Apr 22, 2016
- ny
Tunedwhat spring are you using and are you stock or tuned
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Here's another tip for you Sidewinder guys that might help. I just got a new American Snowmobiler and they was an article on one of their long term sleds (Sidewinder)they said they were blowing belts and took the clutches in for balancing and it cleared up. Pg 23. Here's a picture for you.
kimcoop1324
- Oct 7, 2013
- New Hampshire
- New Hampshire
Thanks for the info about balancing the clutches. Who really knows why some blow belts and some dontHere's another tip for you Sidewinder guys that might help. I just got a new American Snowmobiler and they was an article on one of their long term sleds (Sidewinder)they said they were blowing belts and took the clutches in for balancing and it cleared up. Pg 23. Here's a picture for you.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Dalton Black Orange.what spring are you using and are you stock or tuned
