Hi all. Back to a Yamaha after many many years gone. Picked up a 2018 XTX se 137 with the 1.75” back country track. It’s 100% stock and only has 960 original miles.
It needs slides and the rear axle adjusters are in need of replacement. The stock bolts are rusty in the nuts and one side is loose with one cracked holder. I’d prefer to replace the entire adjuster assembly including bolts, nuts and holders, and also at the same time upgrade the rear wheels and also have the adjusters on the outside of the rails like 19+ sleds.
Between barn of parts, J&t etc I can’t seem to find a definitive proper wheel size for this specific sled, nor an entire kit including everything I need including the bolts and also whether it will allow me to have the adjusters on the outside of the rail. Am I missing something on one of these companies offerings? Is there a better way to go? Stock parts are very cheap, but I’d rather upgrade it all while I’m doing it. Thanks.
