Paul Yarek
- Feb 14, 2016
- 44 King St North RR 4 Scotland Ont
- SRX 120
My grandsons sled if he pinches the throttle quick I'd like to remedy that.
clutches clean?
Paul Yarek
- Feb 14, 2016
- SRX 120
YES it is the engine that stumbles
start with cleaning the carb thouroly.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Do those carbs have an air screw? If so I would richen it up a little if the carbs are clean.
Paul Yarek
- Feb 14, 2016
- SRX 120
It's brand newstart with cleaning the carb thouroly.
take it to the dealer then if it is new. i have bought a new sled that needed the carbs cleaned as it was bogging and fussy. they are not always shipped with the carbs perfectly dry and when the fuel evaporates, it leaves crud in the bowls that get sucked into the carb jets.
Paul Yarek
- Feb 14, 2016
- SRX 120
I was told today it is too warm the carburetor is set up for cold temperatures does that make sense?take it to the dealer then if it is new. i have bought a new sled that needed the carbs cleaned as it was bogging and fussy. they are not always shipped with the carbs perfectly dry and when the fuel evaporates, it leaves crud in the bowls that get sucked into the carb jets.
they are set to run in colder temps but usually if it is fully warmed up it should not bog.
Paul Yarek
- Feb 14, 2016
- SRX 120
Going to find out I suppose
tttario
Did you figure this out? Having similar issues. Thanks
seabeeman
- Sep 28, 2018
- Spooner, WI
- 08 Apex LTX GT 40th
I had the airbox cover on my 22 open up and cause a complete loss of top end and bogging on acceleration. Maybe make sure that is closed properly.
G
