TT
S
This is why we all love TY - thanks
I can on Wednesday if that will help..
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Yes!, I did not investigate to find exactly where the noise was coming from but I hear a noise in that area, sort of a rythmic pulse.Anyone with a 2020 experiencing fluttering noise from there roll over vale. My buddies 2020 Tcat notice fluttering noises coming from the rollover valve at ideal when warm.
thanks
Pan
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Ya It’s normal looked into it checked it out and it’s the rollover valve pulsating.Yes!, I did not investigate to find exactly where the noise was coming from but I hear a noise in that area, sort of a rythmic pulse.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
I took a few pics but it’s hard to see as it’s tucked under the steering post on the 2020..
Sorry guys I tried..
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
early this year someone posted a picture of the new rollover valve on the new 2020. The valve looked to be heated. You guys with the 2020’s can you verify this new valve? Maybe take a few photos. Does anybody know if you can retro fit the new valve for the 17-19.
Here are some additional pictures, including one showing the electrical connections to the part.
Le_Lama
- Jan 27, 2022
- Montreal
- Yamaha sidewinder 2022, Polaris RMK Assault 155, 2018
Hello, would it be ok to remove oil tank hose and hose going to air box and leave the valve itself there with electric wire and sensor plugged in the valve??
Thank you
Thank you
Yes. That’s what I did on my 2020 srxHello, would it be ok to remove oil tank hose and hose going to air box and leave the valve itself there with electric wire and sensor plugged in the valve??
Thank you
Le_Lama
- Jan 27, 2022
- Montreal
You left the 2 holes on the valve open unplugged??
Open.You left the 2 holes on the valve open unplugged??
Upwinder
- Feb 5, 2023
- N0E 1E0
- Sidewinder, Viper, Vector and Apex
I also had roll over valve stock on my 2021 Sidewinder. It is leaking oil out the reservoir again. Even with the jumper hose from fill plug on reservoir to fill plug on valve cover. I don't understand why Yamaha doesn't install a glow timer indicator light. Like my diesel truck has. That would make it easier to make sure you don't start right away, but glow and know to start when light turns off. Someone might be able to make a glow timing light kit. I'll buy it.
Upwinder
- Feb 5, 2023
- N0E 1E0
To give the heat element in the roll over valve time to warm things up before starting.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Again ? Did you already reseal the oil tank ?I also had roll over valve stock on my 2021 Sidewinder. It is leaking oil out the reservoir again. Even with the jumper hose from fill plug on reservoir to fill plug on valve cover. I don't understand why Yamaha doesn't install a glow timer indicator light. Like my diesel truck has. That would make it easier to make sure you don't start right away, but glow and know to start when light turns off. Someone might be able to make a glow timing light kit. I'll buy it.
Upwinder
- Feb 5, 2023
- N0E 1E0
Yes I did it was sealed for about 200km a 1 day run. By Haliburton we had a minus 37 night and I started the Sidewinder around 10:30 am when it had warmed up outside to -22 or so. That hose bypass kit is from barnofparts.com I bought that kit past November.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
You need to remove the rov and do the bypass like most on here have done, clean the oil tank good with brake clean and use permatex “the right stuff” and it should be good for a long time, My oil tank leaked on my first ride on my 20, it’s been good ever since.
