JLR
- Dec 6, 2006
- Winnipeg, Mb
- Currently, 2017 Arctic cat thundercat 2018 sidewinder xtx se 137 precision stage 4, 2025 Yamaha Srx bone stock
good when the trail is smooth lolHonestly the IQS is a joke. The center shock is garbage and the others are progressive springs with basic qs3.
putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
Looks like I have something new to do this offseason. I'll be looking to do the same and sending out to @cannondale27 when I get all new shocks and springs in. Thanks for sharing this build!
putz21
- Apr 15, 2013
- Tomahawk, WI
Thanks @cannondale27 for the quick service on the QS3R with iQS with the Elka Dual Rate Springs for my '25 XTX LE 146". Can't wait to use these this upcoming winter. Now I just need to figure out if there is an option for QS3R's for the Rear Shock on the 146".
Thanks @MrSled for sharing this mod with the group. QS3R with iQS is the best of both worlds.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I am jealous of this set up. I need to find a set of QS3r's for my new Riot 9000
Awesome thank you!
Your welcome!! It’s an awesome upgrade.Thanks @cannondale27 for the quick service on the QS3R with iQS with the Elka Dual Rate Springs for my '25 XTX LE 146". Can't wait to use these this upcoming winter. Now I just need to figure out if there is an option for QS3R's for the Rear Shock on the 146".
View attachment 178823View attachment 178824
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Tell us more about the spring set up. How did you come up this combo? Were there any other options or considerations?
I put on the springs from the 2024 cat RR on the front and set them with sled hanging until jamb nut just touches plus one turn. Center chock used stingray spring and set preload the same and due to my weight of 255 lbs added 4 position cams and run them on the highest setting.Tell us more about the spring set up. How did you come up this combo? Were there any other options or considerations?
screnshaw400
- Dec 3, 2023
- Michigan
- 2018 Sidewinder LTX-DX
- Michigan
Pm sent
FYI, I have sold the old shocks.
