Slow998
- Jan 11, 2021
- Maine
- 2021 Thundercat
- Maine
Does anybody make billet track adjusters for the 19 and up SRX that replace the plastic ones?
RAMSOMAIR
J&T has aluminum ones that come with the 4 wheel axle kit. Maybe call him to see if he will sell them without the full kit?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Grip n rip has a nice billet set also. Turbo Dynamics sells them I believe.
RAMSOMAIR
I believe he is talking about the part the adjusting bolt pushes against on the axle not the insert in the rail. He said plastic, which the 19’ and up have
DMCTurbo
- Nov 12, 2005
Ok my bad.I believe he is talking about the part the adjusting bolt pushes against on the axle not the insert in the rail. He said plastic, which the 19’ and up have
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Hurricane has aluminum ones
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
I have the hurricane ones! They Are very nice but I believe he designed them for 6205 bearings not 6005. I had to make up 1/8" spacers on the inside of each outer wheel bearing or the shaft ends up being longer than the the wheels and spacer combos. Also I made an aluminum spacer tube to get rid of the other plastic between the third wheel and rail with a stainless shim against the rail. This summer I'll add a 4th wheel and cut the spacer tube to fit.
