sledding rocks
- Feb 11, 2017
- north
- sidewinder
does anyone no the part # for the new stryke ski ?
ApexXTX/Viper
- May 5, 2014
- 2019 SRX, 2018 Viper LTX
I have the Tech Tip for them that Yamaha sent to dealers in September but no part # given. It does say that the staggered wear bar supplied from factory only has one row of carbide and that is to be installed with carbide strip on the inside of the ski. It also says the Stryke ski has 4 mounting holes but the stock staggered wear bar only uses the front 3 holes leaving the back(4th) hole "not utilized." The aftermarket bars from Woody's (9975 Series) have four bolts. Stud Boy is confusing. I just called StudBoy and they gave me the CAT 2264 numbers for a 21 SRX but Royal Distributing is showing new part #'s for the Shaper and Deuce Bars. I 'm guessing the threads are a different length. Perhaps Jaret might chime in?
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
i see the stryker ski patent
JMS@Yamaha
The SMB accessory catalog is currently being converted to a digital "Flip" version. It should be released very soon, the Stryke numbers are listed in the Catalog.
-Jaret
-Jaret
ApexXTX/Viper
- May 5, 2014
Any release date for Stryke part #'s and pricing?
TPAY243
- Apr 14, 2013
- Northern Wis
- 2020 Yamaha Sidewinder LTX SE
If it is anything like the 2021 jackets you will have better luck winning the lottery than being able to buy a set.
Big Daddy SRX
- Feb 24, 2006
- Reese, Michigan
- 2018 Sidewinder LTXDX,2014 SR Viper, 2012 Vector LTX, 2011 Apex XTX,
- Reese, Michigan
- AOL
- reesetrailer@aol.com
Has the SMB accessory catalog been released yet?The SMB accessory catalog is currently being converted to a digital "Flip" version. It should be released very soon, the Stryke numbers are listed in the Catalog.
-Jaret
TPAY243
- Apr 14, 2013
- Northern Wis
You could call your dealer and ask it seems that some dealer's are a little ahead of others with the 2021 stuff.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
Guys that are running studs are u changing the carbides or leaving them. If so what make are u going with. I was thinking snow trackers if they are available. Thanks
Bluebullet
- Mar 19, 2005
- Massena NY
- Maine
I am running snow trackers on my 2021 sidewinder LTX GT. The new ski is the same bolt pattern as the cat ski. Tracker Part # 08-20113 Hope this helps!
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
Here's a link to the flip version that I found on the Yamaha website:Has the SMB accessory catalog been released yet?
https://7d89079c.flowpaper.com/2021001059SMPNAUSA/#page=1
VX1R
- Sep 19, 2004
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1986 Inviter
Here's the part numbers from the online 2021 Accessory catalog:does anyone no the part # for the new stryke ski ?
It looks like they're still sorting out the prices.
VX1R
- Sep 19, 2004
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1986 Inviter
I'm going to be running the Snow Studs brand Sniper Double Down 6" carbides on my new SRX.Guys that are running studs are u changing the carbides or leaving them. If so what make are u going with. I was thinking snow trackers if they are available. Thanks
Besides, they're a TY advertiser who supports this site.
Northernshift
- Nov 27, 2014
- 2013 Vector LTX
Did you back off the ski shock preload they insist on in the instructions? I'm happy with the trackers but not happy that my front end is "sagging" downward after backing off the preload.
Bluebullet
- Mar 19, 2005
- Massena NY
- Maine
Not sure dealer installed and set up before I picked it up.
