2023 srx snowtrackers
blown apex
ALTON ILL.
Website
ristermotorsports.com
installing snowtrackers on stryke skies
2023 SRX sidewinder
anybody have set up suggestions
1-zero toe
2-do i lighten front springs like apex
3- i weigh 180 with gear on
4- limiter or front skid spring???
trying to stop darting but corner better
coming from apex ghis sled suspension and power delivery is awsome
i did install 6” slimjims and made darting way better riding back to back with buddies stock sidewinder
Yes IMO front shock springs just snug with sled up on stand. Zero toe. My limiters are all the way out. I run trackers on cat skis.
X2 on what jonlafon1 said, start off with 1 or 2 turns of preload on centre shock and see how it performs, you can also keep center spring bottom locking nut hand tight against the upper one so you can fine tune the preload on the trail till you find the best setting for you.
Running snowtrackers on the 2023, there is a 5mm shim with my stryke skis. Did you guys run the shim still or remove it?
