Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
5mph?!?! That's just what I'm looking for.The 22t should be good for another ~5MPH if you have the grunt. I guess the point of the 22t is that the chain starts out straighter and further away from that post so you have that more adjustment available.
2004yamahaviper
- Sep 11, 2010
- Ottawa, Ontario
- Spring order 2021 srx
2012 Apex xtx
I have been running hurricanes 300hp tune with 22/41 for the last 10,000km on the same chain no issues. Stay on top of your chain adjustment and change your chaincase oil often. Putting a new chain on this season to be safe.
Doc Harley
- Oct 17, 2016
- Here & there
Right on! I just wasn't sure how to gauge stretch? Obviously when you put on the 22t you had to back out the chain tensioner adjuster 6+ threads.I have been running hurricanes 300hp tune with 22/41 for the last 10,000km on the same chain no issues. Stay on top of your chain adjustment and change your chaincase oil often. Putting a new chain on this season to be safe.
I've got 4000miles on stock chain (stock power) the other day I added a bundle increased to 250-275hp this season.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
I had a flash/tune prior to gearing up to a 22T.If you replace a 21t with a 22t, especially on a chain that's stretched out. How & when will you know the chain needs replacement?
Also, I thought the 21t was good for 126mph?
Doc Harley
- Oct 17, 2016
- Here & there
Which tune & do you know what your top speed was with 21t?I had a flash/tune prior to gearing up to a 22T.
I'm not critical..... gps, speedo?!?!
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
And I also needed a new chain after utilizing a 22T for a season or two!I had a flash/tune prior to gearing up to a 22T.
Chain had stretched quick on mine with the 21T, so after putting the 22T and needing adjustment every 800 miles or so, the chain kept stretching so that there was not enough threads left on tension bolt!
New chain is stretching much the same!
