1000 Bound
- Oct 6, 2006
I put a 26 tooth top gear in the apex with the mcxpress for tar racing but it looks like the gear may be too big for the case? It looks as though the chain is going to rub on the chain tensioner just above where the roller is on the tensioner.
has anyone run a 26 top with the stock chain and 38 bottem with success?
I dont want to give up the reverse just yet.
DennisTheMenace
We have run the 26 top gear in a RX-1 with the 38 reverse gear and had no problems. The apex does have a different tensioner, you could switch to a RX style tensioner in you apex case.
lakercr
Tech Advisor
- Aug 12, 2003
- Winnipeg, Manitoba
- 2025 SRX
1000 Bound said:I put a 26 tooth top gear in the apex with the mcxpress for tar racing but it looks like the gear may be too big for the case? It looks as though the chain is going to rub on the chain tensioner just above where the roller is on the tensioner.
You can grind the tensioner a bit for clearance.
1000 Bound
- Oct 6, 2006
I thought about that then just figured it would work itself into place. It rubs ever so slightly right where the post is.
lakercr
Tech Advisor
- Aug 12, 2003
- 2025 SRX
No sense in filling your chaincase with little bits of aluminum when you can leave it on your shop floor...
1000 Bound
- Oct 6, 2006
