Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Should I be concerned?
not liking that rust on the plug. is your sled stored in a high humidity area?
Doc Harley
- Oct 17, 2016
- Here & there
Not really. I did a few good pulls the other day, and the next day I went to start it in the a.m. and instead of idling up to 1800 RPMs she stayed down around 1200 RPMs. Ran it to the gas station then she went into limp mode at 212°. It's running 15°+/- warmer then normal.not liking that rust on the plug. is your sled stored in a high humidity area?
I just rode it a month ago and then two days this week all at 172°. Now high 180's into low 190's.
using any coolant?
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
I would clean the plugs, re-gap, and reinstall. Fire it up and see it your issue continues. Of course you can just out new plugs and see if its OK as well.
Doc Harley
- Oct 17, 2016
- Here & there
Doesn't appear to be. I just wasn't sure if the thermostat got stuck or the water pump is on the verge of taking a dump. Idk....using any coolant?
The sleds running 15°+ warmer than normal. 172° is normal. Now high 180's low 190's. Something's not right. And I've been riding it since 2016/17 season.I would clean the plugs, re-gap, and reinstall. Fire it up and see it your issue continues. Of course you can just out new plugs and see if its OK as well.
NYTurbo
Tuned ?
Doc Harley
- Oct 17, 2016
- Here & there
StockTuned ?
NYTurbo
blow a belt at WOT recently?
Doc Harley
- Oct 17, 2016
- Here & there
No. Never blew a belt.blow a belt at WOT recently?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Didn't your sled sit for a couple of years?
Doc Harley
- Oct 17, 2016
- Here & there
I've ridden every year since new. Last year only 100miles. Typically 700miles a year.Didn't your sled sit for a couple of years?
Do a leakdown test on each cylinder.
Doc Harley
- Oct 17, 2016
- Here & there
I'll have to buy a tester. But yes.....Do a leakdown test on each cylinder.
Doc Harley
- Oct 17, 2016
- Here & there
how does one verify TDC on each cylinder? UGH & sorry
