herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Just got it installed in the wife's Vector LTX. Wasn't to bad to do and only used one shorty and the long spacer as I had thought. Got to get the Nytro XTX in and do the kit on it as well. Probably been easier with a second person. I did have one track adjuster rotate down on me, but was able to pull back the axel and flip it back up.
Pete
Pete
Nytro Nasty
- Oct 17, 2014
- 2008 Yamaha FX Nytro 136, mountain fit vent kit, oft steering relocate, mountaintech skid plate, simmons flexi skiis with 6 dual runners, skinz front bumper, DDM Tuning HID lights, 55 watt ballasts with 4300k bulbs.
All done in one season.
That's is so far but much more on plate for this year!
So will this turn your three wheel rear axle into the 4 wheel style? I want one if so. Where is the best price? Can you get them off any older yamaha that came stock with them? I have billet wheels and would want the 4th wheel to match so don't want wheels just hardware. What are benefits of this?
Nytro Nasty
- Oct 17, 2014
If you don't have a friend to pull on track you could always try a rachet strap. If there is a will there is a way!
So you're saying that all you need to do is cut the existing spacer down 13 mm and use an idler wheel and you have a 4th wheel kit??
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
If you look at it you can see what you have to duplicate. The long spacer is cut twice to make it match the length of the 2 wheel side. You have to cut it twice to make it the same length as the opposite short side and again to remove the bearing width from the longest piece left over. It's been a few years since I did mine, sorry. Once you look at it you should be able to figure it out. All I did was buy a rear idler and cut the spacer using a pipe cutter.
sloan188
- Nov 28, 2012
- Vaudreuil, QC
- 2005 Polaris Fusion 900
2009 Nytro XTX
2010 Ski Doo GSX LE 1200
I wouldn't think it would be quite that easy but almost....The spacer is currently long enough to fill the void between the existing inner wheel and the rail and there is smaller spacer between the rail and the existing inner wheel....so you would likely need to cut the longer spacer to create one more short spacer to go between the opposite rail and the new inner wheel and you would be left with another spacer to go between the wheels that needs to be trimmed 13mm.
canoehead
- Jan 14, 2011
- NE, Alberta
Use your short one as a template more or less and cut that much off the long one. Then remove the 13mm from the long one left over
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Here you go, full instructions on making your own 4th wheel kit:
http://www.totallyamaha.com/snowmobiles/aaTECH/4th_wheel_kit.htm
Nytro Nasty
- Oct 17, 2014
Anyone got pics of both set ups to give us ideas on what needs to get done as far as mods? Picture is a 1000 words and would be helpful I am sure. As I want to do the same! Thanks guys
