Check the primary clutch sheaves for cracks or deep grooves. Replace as necessary. Check front suspension bushings for play, replace with AFTERMARKET as necessary. Check the jackshaft and driveshaft bearings on the PTO side. Check the secondary clutch ramp buttons for wear and replace WITH OEM if worn.
Yeah drive side bearing already done long time ago. I'll check my clutch
for the wear... thats soft of what I was worried about but I wasnt sure if 5000 miles was enough or not.
