benjamingvsu
- Oct 9, 2007
- Stevensville, Michigan
- 2014 Viper rtx se
I logged 615 miles on a 600-etec over the weekend.
This sled lacked the power/excitement of the Vector EFI motor I rented last year. Good power, just not "grin every time and hold on tight" power like the Vector was.
However, I felt that it handled more precisely/easily. It seemed to corner easier and took less effort to push hard through the trails; suspension handled the pounding better than the monoshock ( probably just a set-up issue)
We got between 12 and 18 MPG every time we filled up, with the average right about 15.5.
Used 6 quarts of oil. I remembered why I won't buy a two stroke!
I'd like to ride the 1200 renegade and the nytro XTX to see which I like better.
Phazernut
- Nov 2, 2007
- Torbay Newfoundland
- 04 Viper ER.
96 V-Max 4
6 quarts of oil sounds high. A friend has one of those and he doesn't come even close to that in oil burn. I do agree with you on the other statemnts though.
pat the rat
- Mar 13, 2006
saw 1 with a burnt engine last week,guy was not impressed,it wasnt the time to start talking about other brands
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
I love the handling of these 600's but your right the power is like a 440 compared to my SC apex. I could never ride on no matter how well they handle LOL
benjamingvsu
- Oct 9, 2007
- 2014 Viper rtx se
Yes, I was pretty disappointed with the oil and fuel mileage. The dealer claimed we'd get no less than 18MPG riding hard, and could count on 200 miles a tank, and also claimed we'd use about 2 quarts of oil every 500 miles. I posted my results on the yellow website and got 0 responses.
09nytro
I work at a ski doo dealer (as a wrench) and I replaced 4 eng this year
Called them on each one they said replace the Eng. Well that's good but still didn't fix the problem they said they have not had any problems with them one leaned out so I guess they will be back. The one that leaned out they said if it comes back we will have to replace both objectors and the ecm. They wouldn't give atho to do it this time. I feel bad for these people
mbw919
benjamingvsu said:I logged 615 miles on a 600-etec over the weekend.
We own a carbed Vector and a 600 E-TEC. I agree with the power comparison. The Vector just pulls harder. Our Ski-Doo is a GSX short track so the gearing is probably a little different than the Renegade, but we get way better fuel and oil mileage. We usually get 22 to 24 mpg and the first gallon of oil lasted nearly 1400 miles. Yes, it gets ridden fairly aggressively.
mbw919
Curious if you work at Extreme Powersports? We got our GSX there.09nytro said:I work at a ski doo dealer (as a wrench)
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
The 600 Etec in our group is pretty close to that, he is right around 16-17 mpg and a a quart of oil every 150-200 miles. His FIRST engine, which made it 2700 miles, averaged ~20-21mpg and a quart every 300 miles so I think the de-tuned his computer a bit. Its probibly cheaper for Skidoo to replace the whole engine block than change injectors, those are VERY expensive. buddy has had to change one on his 60hp Etec outboard along with a piston.
- 6K
- 7K
