Guys if you look at the 16's and maybe 15's the 8mm bolts with 10mm heads have been upgraded to 10mm with 13mm heads on all sleds 129" and 137". Noticed it when I found one of mine snapped off. The bolt is the one that holds bottom of rear scissor to the rail. I drilled and tapped for the bolts but you can order the shaft and bolts from a 16. You will have to drill the rail to fit the bolt.
So it got me thinking. I don't like any of the 8mm bolts. Good enough for holding wheels on but not the shafts. I replaced all with 10mm shoulder bolts. That way if one should happen to come loose the thread wont dig into the rail. Much stronger and longer. Just a heads up.
8mm on left,10mm shoulder bolt on right.Cant take credit for the shoulder bolt idea. I got that from YAMAHA!
