Subframe bolt torque
markowinnipeg
New Bothwell, Mb
Reinstalling my straighten reinforced subframe and cannot find anywhere in manual torque spec's for the 12 frame bolts?
Are you using blue loc tite on them.
Also stripped those crap allan bolts on sway bar blocks, is it ok to replace these with just a standard 8mm metal bolt I think the Yamaha ones are stainless steel.
Thanks for any help
If you are looking for these (#4) they are 18 Ft.Lbs.
I put blue locktite on them.
I don't see a problem using the same size/thread bolt to replace it. I would get a stainless though.
Yes that is them, thanks I looked everywhere cept the engine part in manual.
I am going to go with a normal bolt so I do not have to deal with the stock ones stripping again.
