kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
I have looked for over 2 hours for the bolt, and I cannot find it. Makes me mad I have been so diligent with this thing and meticlous that I wanted it perfect when done, and now I have a bolt missing somewhere. I wouldn't care if it was outside of the sled and order a new one but I don't know if its inside the sled somewhere.
I checked in the exhaust valves, in the insulated tray that the flex sections sit in, behind the chaincase, down the entire side of the front heat exchanger, on th tunnel, in the the area around the muffler, on the floor, on the workbench, in the pile of parts I have laying around. Nothing. the 8th wonder of the world....
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Try moving the sled around, on it's sides, lift up the front, lift up the back, shake and do the hokey pokey a few times. Maybe the missing bolt will reappear.
Oh yeah, I forgot, turn yourself about...
Cause that's what it's all about.
kinger
- Jan 17, 2005
- Clear Lake, IA
LOL, thanks grimm, now I just need to figure out how to lift 600lbs around like that LOL!
Are you absolutely sure the bolt did not go in engine? I think I would pull the engine and get very serious about where the stud is.
kinger
- Jan 17, 2005
- Clear Lake, IA
Yep absolutly sure, I removed the plugs and used my magnet finder in there, and I also looked in all exhaust ports. Its IN the engine just may be somewhere else.... dang nab it...
you mean the engine bay right?
if it is in the motor that could get really expensive.
kinger
- Jan 17, 2005
- Clear Lake, IA
Found it!!!!!!!!!
Grimm you are the man, I have no idea why I brain farted and didn't think to toss the sled around, I flipped it up on its side, heard it move and used my magnet to retrive it from the lower front part of the front heat exchanger!
Thanks so much I'm soooooo happy now!!!!
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
You are welcome.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Glad you found it
Been there done that, it doesn't feel any good when bolts go missing on assembly.
I was going to mention....its down there! Because that happend to me 2....sucked getting it out. Because like me, you probably have 90% done bolting and hooking up the motor at that point.
Great to see you found it. Thinking its in the motor will make you loose sleep.
kinger
- Jan 17, 2005
- Clear Lake, IA
Yes I am happy, now to finish it up and get to work on the driveshaft and track change. tired of worrying about it and want to get to gettn'
I can't tell you the number of times my chubby fingers dropped bolts, washers, carbuerator components under the engine bay on my SRX. There were times I would spend hours tipping the sled back and forth, hoping it would at least fall into a place where I could see it and get a magnet in there. Glad you found it and now you will know the procedure for next time.
