YukonMP
- Dec 25, 2014
- Yukon Territory
I got mine from Yukon Yamaha in Whitehorse. They had stock a month ago.
ArcticRider
- Nov 19, 2018
- Above the Arctic Circle, Alaska
- 2016 Yamaha Viper STX-DX 146
2021 Vk 540
I did find them on a Canadian website but no where else. Ive read that the vk540 is popular in Canada and Russia so I guess that makes sense.They used to be only available in Canada. Not sure if that's still the case though.
ArcticRider
- Nov 19, 2018
2021 Vk 540
QUOTE="YukonMP, post: 1546725, member: 23891"]I got mine from Yukon Yamaha in Whitehorse. They had stock a month ago.[/QUOTE]
I emailed them to see if they ship to alaska
ArcticRider
- Nov 19, 2018
2021 Vk 540
Got a hold of yukon yamaha and the nice fella there is going to ship em out to me!I got mine from Yukon Yamaha in Whitehorse. They had stock a month ago.
He also said they dont carry the 11” because they have a tendency to break in cold weather and it gets crazy cold up here so im going with the 9”.
christoph
- Oct 12, 2020
- Idaho
- 2007 VK Professional
How wide are those 2014 factory skis? I've got Gen I Simmons on mine and looking for something wider
christoph
- Oct 12, 2020
- Idaho
Has anyone put a set of the 13-15 model year skis on a 2007ish VK? Is it a direct fit replacement? My sled has a set of Gen I Simmons the 6" ones and they just aren't cutting it for breaking trail and getting enough bite. Gotta figure out the trick to getting some more ski pressure once I get some wider skis. I've found a set of Gen II Simmons that'll be my backup plan. Thoughts?
20/80
- Mar 25, 2010
- Nova Scotia
- 2016 APEX LE XTX
The newer VKPro skis are 7" deep keel and are made to help with backing up with a higher curve at the back, I run them on my 16 Apex and has made a huge difference in keeping her up on top of the deep stuff, I also put snow trackers on to fix the darting, this setup works very well on my sled where it is heavy in the front, not sure if this helps.Has anyone put a set of the 13-15 model year skis on a 2007ish VK? Is it a direct fit replacement? My sled has a set of Gen I Simmons the 6" ones and they just aren't cutting it for breaking trail and getting enough bite. Gotta figure out the trick to getting some more ski pressure once I get some wider skis. I've found a set of Gen II Simmons that'll be my backup plan. Thoughts?
chateaupitsie
- Nov 10, 2017
- Nunavut
- 2011 550f grand touring, 2000 440 Bearcat, 1998 340 Bearcat, 1984 Scandic 503, 1989 Safari 377, 1988 Bravo LT,1983 Everest 500, 2009 600 Polaris Switchback, 2016 VK Pro ii,
The 11” inch skins are a good option. Provides extra flotation in powder and stability on trail and in the rough stuff when you have low snow conditions. Dooley double carbides helped with the darting but caused an unintentional hard steer-workout on non- power steer models before 2017 on most VK Pros it would seem!
toplot
- Jan 9, 2022
- Manitouwadge
- 2021 vk professional
Where did you purchase your wide ski skins. My dealership told me they did not exist for my 2020 vk pro. ThanksI went with the 11" ski skins helps with the tippyness and also tune down front suspension from setting 1 to 3rd setting helps stability and no darting. Looks kind of goofy but works good. The mod on the exhaust has kept ice build up in tunnel at a minimum.
YukonMP
- Dec 25, 2014
- Yukon Territory
SKU SMA-8FNSK-11-BKWhere did you purchase your wide ski skins. My dealership told me they did not exist for my 2020 vk pro. Thanks
That is off the Yamaha Canada website. I've been meaning to post on this thread since I saw the comment that the 11s are fragile. That is what my dealer told me and they are the source of that comment in this thread.
The VK Pro is a wide sled made wider by 11 inch skins, it may not fit between any two trees that buddies sled just passed between. I need the extra width and will not cry if they get cracked. Right now there is almost two feet of powder on the lake and they are saving my #*$&@.
chateaupitsie
- Nov 10, 2017
- Nunavut
The 11” skins are available from a few places on line. A cursory check yesterday saw a few sites pop up. Mine cane from the local Yamaha dealer. They are not in stock now there.
bobberal
- Mar 18, 2020
- Walker, MN
- 2015 VK Pro
What dooley did you use?The 11” inch skins are a good option. Provides extra flotation in powder and stability on trail and in the rough stuff when you have low snow conditions. Dooley double carbides helped with the darting but caused an unintentional hard steer-workout on non- power steer models before 2017 on most VK Pros it would seem!
