Tayz588
Hey I cleaned the carbs on my dads 98 v-max and when i went to start it the thing just sounds like its hitting on 1 cyl. Turns out both have spark and both are hitting at basically the same time. I know the carb and jets are good and clean, I hooked all the wiring up again, fuel lines, cables, etc. Anyone have a clue whats wrong. It just bogs when I give it throttle. Oh yeah and Its got fresh gas. Tried different plugs, pretty much every trick i could think of. Anyone have any idea's?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Check the cables My 2000srx did these to me once and the gas cable came out
Tayz588
Alright I'll go check that! anyone else have anything? Thanks APEX for the suggestion!
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Ok let us know
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
You may try posting on the 2 stroke side for info on that one.
Tayz588
I didnt know there was one..maybe i'll switch it over, and APEX, turns out the throttle cable is functioning and turning the guide
srxtwins
You may have a problem with the tors. Try connecting the two wires together at the sled side of the carb switch and see if it runs properly.
Werent those known for catching a ring on the port?Do a compression check.
sleddingfarmer
srxtwins said:You may have a problem with the tors. Try connecting the two wires together at the sled side of the carb switch and see if it runs properly.
x2 had that problem on my brothers 600.
YamahaOutlaw
cannondale27 said:Werent those known for catching a ring on the port?Do a compression check.
YES THEY WERE! I had '97 XT 600 that wiped out a cylinder by doing that, and my dad had a 99 VMAX 500 that did the exact same thing. Those motors were notorius for that up around 5-6000 miles. If that's the case, when you rebuild the top end, chamfer the edge of the ports a bit!
DoktorC
Check your throttle cable free-play...sounds like you've got it too tight and it's activating the TORS. Make sure the cable is seated correctly in the throttle block (on the bars) as well.
- 12K
