wincher
- May 5, 2010
Please help I am chaseing a squeek in my front end. It started last summer when I would get on the throttle in a turn. Now it is almost all the time. The most happens when you get on it or right as you back off. Just replaced a wheel bearing but that didn't help it. Picked the thing up last night with my tractor and it will even do it a little with no wheels on the ground. But I still can't be sure where it is coming from. Thanks.
Ganz
The bushings in the a-arms will squeak and I've had the steering stem do it too. I just took them all apart, cleaned them and greased. Helped for a while but it came back. Losing battle in my opinion.
wincher
- May 5, 2010
No this is not a body issue. It is somewheres in the drive train. It changes with tire speed. It is also getting louder as you ride longer.
dry cv boot? might have thrown all the grease out or you have a bad u-joint.
Ganz
maim said:dry cv boot? might have thrown all the grease out or you have a bad u-joint.
Yup, what he said
wincher
- May 5, 2010
nope! took them apart yesterday and they felt smooth both ends repacked with grease. Then rode hard for an hour with no change.
might be the rear u-joint. that one is a pita to check/replace.
RX Buck
- Sep 11, 2003
- Grand Rapids MN
- mobilepredictive.com
- 2017 Yamaha Sidewinder LTX
- MN
Most likely the front spline. That is what sqeaked in my front end. Just take the front hub off and grease the splines.
