NytroBite
- Nov 30, 2014
- Stevens Point, WI
- 2010 Nytro RTX
I have a 2010 rtx and noticed quite a bit of upper a arm play at 1500miles. I replaced all bushings upper and lower with oilites. It tightened up pretty nice but the left upper seemed to have slightly more play after new bushings compared to right. I now have 2600miles and the left upper seems to have a lot of play. Even torqued it to specs why does it have so much play even after new bushings???
radianguy
- Jan 1, 2007
Arms may be ovaled out where bushings go? Frame ovaled out?
NytroBite
- Nov 30, 2014
- Stevens Point, WI
- 2010 Nytro RTX
The bushings fit very tight into the arms had to use threaded rod and washers and they seated flush. I will have to take a closer look at the frame but all seemed well before. I do ride hard and take a lot of jumps so that doesn't help.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
I had to re tighten bolt on my upper left after a season as it has some play. Wasn't much maybe 1/8" of a turn with ratchet. Try tightening more and see how it goes
NytroBite
- Nov 30, 2014
- Stevens Point, WI
- 2010 Nytro RTX
I will try that. I did locktite it so it shouldn't have loosened at all but maybe just needs to be tighter
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Mine was loctite'd too aw well lol just backed off a touch over the season
NytroBite
- Nov 30, 2014
- Stevens Point, WI
- 2010 Nytro RTX
Found out that the plate on the frame where the bolt goes threw was bent out so the bushing of the upper a arm wasn't completely touching. Bent back and it tightened up but the hole is also very lightly egged out but enough to make some play. How would you suggest fixing that. Just weld around the hole then grind flat and drill out or weld a washer in place?
Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '21 SRX, '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F,
Contact Grizztracks and he will have the answers for you. His gusset kit will fix the bending of the front sub-frame and he has solutions to the egged-out holes and small nuts that the a-arms are bolted into.
NytroBite
- Nov 30, 2014
- Stevens Point, WI
- 2010 Nytro RTX
I already
NytroBite
- Nov 30, 2014
- Stevens Point, WI
- 2010 Nytro RTX
I already had his gusset kit welded in. The frame itself didn't bend just that small tab the a arm bolt head sits against. I will ask him about the egged out hole fix.
