bluegrass
- Mar 6, 2007
I checked out the front and had play in the tie rod end and upper ball joint now that I have replaced all of the that I have play in the upper a arm I can more them back and fourth so I don't know if this is a normal thing the sled is a 2012 nitro xtx has 900 miles out it sould there be any play in the a arm at all
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Safe bet they're done. Should be zero lateral movement in the arms. I didn't think mine where bad until I installed the new oil-lites.
bluegrass
- Mar 6, 2007
Ok I am getting a front to back movement I think that is what you are talking about they seem to be good up and down
NS FX NYTRO
I just went through my nytro and the only thing tight is the lower a-arm bushings. The upper ball joints have a little play, but 90% of the play on mine is from the upper, inner a-arm bushings. $75 gets you all 12 oilite bushings, so mine is getting them all replaced, then I'll go from there. I have owned a few sleds and have never replaced these items. Now if the exhaust doughnuts hold up for the rest of the season I'll be happy!
canoehead
- Jan 14, 2011
- NE, Alberta
Yes that's the lateral free play I'm talking about. I didn't think there was much on mine like I said until I checked after installing new ones.bluegrass said:Ok I am getting a front to back movement I think that is what you are talking about they seem to be good up and down
