grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
You'll need to get a angle indicator. I'm at 23-24 degrees of caster and 2-3 degrees of negative camber but because everyone's suspension is set a little different you may find a need to tweak it from there. I removed the skis and placed the spindles on two leveled wood blocks to set the initial camber. With the skis reinstalled I then set the initial caster which is more difficult because it changes with the suspension ride height. I started around 26 degrees of caster and then reduced it from there. The final step is to check/reset toe after adjusting caster and camber.
